Hi all, I am a university student using PrePoMax for my final year FEA research project, in which I am modelling a elastomeric-and-steel-cord conveyor belt (i.e. steel cords held in a rubber casing). I have created the model in FreeCAD and have so far been using Extrude meshes for my simulations. (I also have another post open asking a different question relating to my project)
I have watched the both Hydrostatic Pressure videos listed in the PrePoMax manual, but in both scenarios the model pressure varies with position while in my model I have assumed that the load is uniform across the surfaces that it is applied on. I tried using some settings that I thought made sense (specifically I set the pressure change direction parallel to one of the model edges since I have assumed the load is uniform), but the simulation answers I got were notably different to the answers I worked out myself using my deflection theory lecture notes (larger by a factor of about 14x).
Is there a specific way I should be setting the load parameters? Thanks.
PS. for reference I have included a small-scale version of my model, with the bulk material in yellow and the protective rubber in dark grey.
