hi,
i tried latest development version (1.5.1) and it seems can not import IGES and VOL files properly. This problem does not occur in stable version (1.4.1) and previous development (1.5.0)
detailed error message shown below,
11/09/23 13:13:54 Set new model properties: Model space: 3D, Unit system: mm, ton, s, °C
11/09/23 13:13:59 Import file: C:\Users\user\Documents\plthl.igs
11/09/23 13:14:00 Running command: C:\CAE\PrePoMax v1.5.1 dev\NetGen\NetGenMesher.exe IGES_ASSEMBLY_SPLIT_TO_COMPOUNDS "C:\Users\user\Documents\plthl.igs" "C:\CAE\PrePo...
11/09/23 13:14:00 Max v1.5.1 dev\Temp\bIMomxbX.brep"
11/09/23 13:14:00 Total number of loaded entities 66.
11/09/23 13:14:00
11/09/23 13:14:00 Number of colours in IGES File: 0
11/09/23 13:14:00 Highest entry in topology hierarchy:
11/09/23 13:14:00 1 solid(s)
11/09/23 13:14:00 Successfully loaded IGES File: C:\Users\user\Documents\plthl.igs
11/09/23 13:14:00
11/09/23 13:14:00 Elapsed time [s]: 0.1727762
11/09/23 13:14:00
11/09/23 13:14:00 Running command: C:\CAE\PrePoMax v1.5.1 dev\NetGen\NetGenMesher.exe BREP_VISUALIZATION "C:\CAE\PrePoMax v1.5.1 dev\Temp\bIMomxbX_solid_0001.brep" "C:\...
11/09/23 13:14:00 CAE\PrePoMax v1.5.1 dev\Temp\geometry.vis" 0.01
11/09/23 13:14:00 Ng_OCC_Load_BREP
11/09/23 13:14:00 Successfully loaded BREP File: C:\CAE\PrePoMax v1.5.1 dev\Temp\bIMomxbX_solid_0001.brep
11/09/23 13:14:00 Ng_OCC_ExportVisualization
11/09/23 13:14:00 Building visualization mesh:
11/09/23 13:14:00 Preparing visualization (deflection = 0.01) ... done
11/09/23 13:14:00 Exporting solids: 1 ... done
11/09/23 13:14:00 Closing visualization file. ... done
11/09/23 13:14:00 Export visualization finished successfully.
11/09/23 13:14:00
11/09/23 13:14:00 Elapsed time [s]: 0.2664719
11/09/23 13:14:00
11/09/23 13:14:01 Error: The file C:\Users\user\Documents\plthl.igs could not be imported correctly:
11/09/23 13:14:01 Index was outside the bounds of the array.
11/09/23 13:14:01 at PrePoMax.Controller.ImportBrepPartFile(String brepFileName, Boolean showError)
11/09/23 13:14:01 There were errors while importing the file/files.
and previous version which successfully loaded and displaying IGES and VOL files,
