I just see that there is the option to merge coincident nodes, but is there a way to make a simmetric copy of a meshed part?
There’s only Translate, Scale and Rotate under Part —> Transform in the FE Model tab.
some work around by exporting successful meshed part then reimported, but add an option to copy in menus can be good feature to simplify.
More about mirroring meshes here: How to apply symmetry to honeycomb core unit cells - #12 by FEAnalyst
It would indeed be helpful.
Thanks! An yes, a direct mirrowing operation would be vey usefull.
