Export individual (selected) meshed parts
I use a lot Prepomax for meshing, and very often I need to export some parts of an assembly, not all the parts. Could it be added an option to export only the selected meshed parts?
As a workaround, you can run Check Model and use deformed mesh export to .inp:
Could it be, but would be more fluid just selecting the part(s) in the model tree and having the export option in the contextual menu, without extra steps.
I think I can add the same behavior as is done for geometry export.
I have reworked the Export menu. The Mesh menu supoprts export of selected part meshes (and a little teaser for the next version).
12 posts were split to a new topic: Assembly joints for solids and shells
