Hello all. I am trying to learn prepomax and i have only done a FEW tutorials from FEAnalyst ( a member here) on youtube.
I do not have the ability to draw a pretty picture but i do have a picture i drew in power point.
In the very crude attached image of a cross section of the closure end of a pressure vessel, you will see a shaft that was molded/drilled into some rubber type material. about 1/8th inch diameter (3mm or so). The countersink bore at the top surface is 0.310 inches in diameter (7.62mm). The orange line is the surface of the rubber material. The hole is partially on a curved surface. The rubber is about 1 inch thick. The shaft and bore are molded into the rubber or drilled out depending on purpose.
The purpose of this shaft is to install a pressure sensor at the bottom onto a metal plate, usually aluminum. the Countersunk diameter is meant to only allow enough hot gas and the pressure to go down the shaft to the sensor without eroding the rubber material away.
My goal with a 2d flow analysis, is to see, if i “accidentally” increase the counter sunk bore from 0.310 inch to 0.5 inch, BUT keep the shaft bore the same:
1.how much heat/temp increase happens on the surface of the rubber INSIDE the countersunk bore from increasing its diameter from 0.3 inches to 0.5 inches and how deep does that change go? (blue and red lines on the image)
the information i have gathered up is 1.5m/s for gas velocity in THIS region alone. Other areas its much different, so pretty slow for the gas flow. For pressure, this vessel is under 1100PSI for 60 seconds, then the last 9 seconds, the pressure begins to drop to 0
Temp of gas in the chamber is 3300K, dynamic viscosity is 1.0x10^-4 Pa*s, gas density is 6.9kg/m3
For material it is SFEPDM
thermal diffusivity is 1.6E-7
density is 1040000g/m3 or 1.04g/cm3
Cp = 1850J/kg*k
k = 0.30W/mk
I am not sure what analysis type to run to answer my question.
thanks for any help. I am new so im going to need some help and guidance.
