mechanical calculation including the thermal expansion
The temperature increases from the room temperature up to 600°C between t=1s to t=2s; i’m not figuring out why in the mechanical simulation, T=600°C at 1s => what i’m missing (maybe be in the step definition)?
Thanks
Paul
Following screenshots follows data from the “spy” node
I guess CalculiX wants to apply 600°C at the end of the step. Your static step ends at 1 s. If you extend it to last 2 or 3 s then 600°C will be applied at 2 or 3 s:
I did such a simple test and compared it with Abaqus. The behavior is different. Abaqus maps the whole time variation of the temperature and sets 20°C at 1 s while CalculiX simply takes the value from the last increment (there’s no BINC parameter here) and applies it to the last increment of the mechanical analysis.
If i set aside thes issue in using thermal .frd files, i’ve modified the model using “Coupled temperature-displacement step”; i think all inputs have been defined (including the gap conductance) but the FEA does not start and i do not understand why?
I’ve the following warning but i’m wondering if the issue comes from: any suggestion?
*WARNING in calinput: no conductivity
constants were assigned to material SURFACE_INTERACTION
in a thermo(mechanical) calculation
hmm… i never tried this before but I have the feeling that no matter what step number is entered for the temperature field, always the results of the first step will be used.
At least I would have expected an error if the entered step number cannot be found in the .frd file:
There’s a generic error message “Job failed - no results exist”. It usually means some modeling error. I would simplify the model to find which feature causes it. As I said before, such tests should be done on simple models first before proceeding to the actual usecase.
Btw. your pre-tension is applied incorrectly. It should be applied to interior face of a bolt split into two parts with boundary layer defined: https://www.youtube.com/watch?v=7ucoBTqCcWE
