Export Clean PMX file
As always its just a suggestion/wish. Usually my colleges want to see how I setup a model so they can run it themselves. I am wondering if there is a way to dump most of the file size with an export button with options to remove history, remove results and remove meshes. This would leave only the bare minimal PMX which is usually a very tiny file. Removing meshes does create an issue where node sets would loose their nodes. Usually I have to consciously keep my meshes small so that I can share, or change the settings so that the meshes are small before sharing. I did a quick search on this topic, I will continue searching for what others do for sharing setup models.
