Hi, when I’m busy getting a good setup for a simulation, I often need to fine-tune parameters to get the simulation done. To compare my modifications, I take all settings and parameters by hand into an Excel sheet to have a quick overview of what has been changed. It would be very nice to have an overview of the mesh settings, materials, surface behavior settings, etc. in a file that can be imported into Excel or any other type of document. It would also be nice if it were a format that can be used by Python scripts.
Looking forward to your reaction.
Kind regards,
Adding such a tool is somewhat difficult since all users will have different ideas of what to copy/save. But I can look into copying the entire property grind to the clipboard. Would that be useful?
This could also fall under basic report generation (for the preprocessing part) - export all the model settings to a file. However, a button to copy all settings from the property grid would also make sense. Something like the current “Reset all” button:
I bring this topic again. Extracting all parameters out of the setup will help to collect data for AI modeling, debugging, and writing simulation reports. So I would greatly appreciate it if we could extract it. On Mecway it’s much easier.
Thanks,
Roland
Now all features in PrePoMax are supported by Python, and Python can be used to extract all information from the model. So, using a script, this is easily doable.
