Duplicate Function
Good day,
Would it be possible to add a “Duplicate” option with a mouse right-click to copy an entry ?
This would reduce repetitive mouse clicks by not having to go to the menu bar every time. I guess this feature could be applicable to Materials, Sections, Constraints, etc.
At the moment you can duplicate some items that are more or less independent. Like a material. But not a constraint or a section since a lot of settings must be changed for the duplicated item to make it work.
Maybe it would be useful to use it as a backup. So first duplicate the item, then disable it and then make changes to the existing item?
And you don’t have to go to the menu to create new items, you can double-click (or right-click) the main tree branch: Constraints (in your case).
Implemented in v1.4.1 so I’m closing this.
