Material Section
Hi, I am designing a composite facesheet.
Everytime I run the simulation I got the following message, that material selection is missing. How can I add that?
Yes, its set as ELM_plate
This error shows up because you added the section manually via keywords and it checks for the assignment in GUI (model tree). It should run if you click OK.
To prevent that warning, you could add a dummy section property to all elements in the GUI - before the user-defined keywords. The section properties are overwritten when multiple are defined for the same region.
