Hi @Matej, again compliments for the latest PPM 2.2.0 that is a terrific improvement, especially because it is now based on CC 2.22 which (is it just me?) seems much faster than 2.21. I’d like to report on the following issue: when I create a ref point and then duplicate and then edit the duplicate I get this error message
“property accessor region type on object … threw the following exception specified method is not supported”
After the error I can still work normally.
It happened several times but not on startup, so you have to load a model to see it.
It occurred to me with two different models so I don’t think it’s on my side.
Anyway it is possible to circumvent it by avoiding to duplicate and creating the new ref point instead.
Thanks,
Andrea
I also noticed this bug and somehow forgot about it. So, it is confirmed. I will try to fix it.
I have fixed the problem, the fix will be included in the next version.
Great, but I tried the new version and I now have a problem in applying a concentrated force. In fact I have to use the order version.
True, I can reproduce the problem. I have fixed it in version 2.2.2.
Please confirm it is fixed.
