Hello everyone! I hope you’re all doing well!
I’m having trouble solving a simple problem in Prepomax. I created this model mainly to compare accuracy. In this comparison, I noticed that the peak stress in a T-shaped part with fillets differs significantly from the answer.
In both cases, I am using linear mesh refinement (first-order) with 0.5 mm, a Poisson’s ratio of 0.3, and a yield stress of 200 MPa. The image below shows the results.
The results only became similar when I practically removed the effect of Poisson’s ratio in the Prepomax material, setting it to 0.01 (which seems quite strange). The images below show these results:
I would like to ask if this issue is common or if there is any parameter I need to adjust in EDIT CALCULIX KEYWORDS? The constraints in the model are identical in both cases.
Thanks in advance!
