Density of edge increse or decrease after meshing
how to change density of elements on edge after meshing
You can use the mesh refinement tool for that:
It is not possible to do it after meshing. The meshing must be repeated with additional settings.
hi!
if we use mesh refinement we can correct by changing element size , but i want to change the density only on specific edge
like an edge having 6 nodes we have to change to 5 nodes or 4 nodes
You can set Mesh Setup → Mesh refinement only for selected edges.
but there will be so many edges to do that refiniment.
this feature can be similar,
