Hi There
I’ve recently been experimenting with PrePoMax and I was trying out FEAnalyst’s tutorial 16 (https://www.youtube.com/watch?v=Y0Fass1_iuo) However I couldn’t get it to work in v1.4.1 in the end I changed back to v1.4 and started again and found the tutorial worked fine there.
I then took my good 1.4 model and opened it in 1.4.1 to see if it would work, unfortunately it gives the this error:
*ERROR reading *CLOAD: node 18305
is not defined
*ERROR reading *CLOAD: node 18307
is not defined
*ERROR in calinput: at least one fatal
error message while reading the
input deck: CalculiX stops.
Job failed - no results exist.
To investigate further I performed a diff on the .inp file generated by 1.4 and the .inp file generated by 1.4.1 and you can see that the nodes have corrupt data in them.
I haven’t done much more digging but this seems to be related only to rigid body constraints.
