Hello Dear PrePoMax community! First of all, thank you and congratulations for all the hard work that is going on to have such an outstanding piece of open-source software for FEA simulations.
I’ve been trying to import the following input file from the CalculiX Discourse group: Unexpected displacements in contact analysis. However, the *SURFACE keywords are giving me some “soft” errors:
Error: Failed to import surface  Fixed_surface: *SURFACE, NAME=Fixed_surface, Type=Element
Error: Failed to import surface  Symmetry_plane: *SURFACE, NAME=Symmetry_plane, Type=Element
Error: Failed to import surface  Load_surface: *SURFACE, NAME=Load_surface, Type=Element
Error: Failed to import surface  Primary: *SURFACE, NAME=Primary, Type=Element
Error: Failed to import surface  Secondary: *SURFACE, NAME=Secondary, Type=Element
I’m just trying to pinpoint the issue, and it seems that the surfaces have the correct element number and face ID. Not sure what is going on with the reader. Maybe it needs to be an element set instead of a column list? Where could I get more information about how this is imported into the source code? Maybe I can do a few tests and provide a patch.
Thank you for your time!!
