Contact analysis results in no displacement
I have tried to follow the contact tutorial here: Link using version 1.3.4 (tutorial is 0.7.0). I have a very similar setup with one (metal) part being pushed inside another (plastic) part.
Analysis completes but there is no displacement of the plastic part. The two parts simply pass through each other.
Any suggestions of what I am missing?
Thanks
It seems that contact is not properly detected. Make sure that pairs are correctly defined, try with adjustment.
Be careful to set proper time increments. If the time increment is to large the contract will not be detected.
Ok let me try those suggestions
