Compresion Only Support + Initial Temperature Field
When trying to define a Compression only support in presence of a Temperature Field ccx stops with the following message:
*ERROR in checktemp: no initial temperature
defined in node 2089
Is it possible that the new gapuny nodes are waiting for the initial temperature to be assigned?.
Yes: Error in checktemp - #8 by FEAnalyst
Thanks for confirming,
I have applied a default initial temperature as the other nodes and now works fine.
:+1:
I am trying to reproduce this problem with no success. Can a simple file with this problem be shared?
This one would fail without the added keywords.**Added by hand. If not fails
*Heading
Hash: gKPLT3gS, Date: 01/03/2025, Unit system: M_KG_S_C
*Node
1, 0.00000000E+000, 0.00000000E+000, 0.00000000E+000
2, 1.00000000E+000, 0.00000000E+000, 0.00000000E+000
3, 1.00000000E+000, 1.00000000E+000, 0.00000000E+000
4, 0.00000000E+000, 1.00000000E+000, 0.00000000E+000
5, 0.00000000E+000, 0.00000000E+000, 1.00000000E+000
6, 1.00000000E+000, 0.00000000E+000, 1.00000000E+000
7, 1.00000000E+000, 1.00000000E+000, 1.00000000E+000
8, 0.00000000E+000, 1.00000000E+000, 1.00000000E+000
9, 1.00000000E+000, 1.00000000E+000, 0.00000000E+000
10, 1.00000000E+000, 1.00000000E+000, 0.00000000E+000
11, 1.00000000E+000, 1.00000000E+000, 1.00000000E+000
12, 1.00000000E+000, 1.00000000E+000, 1.00000000E+000
13, 0.00000000E+000, 1.00000000E+000, 1.00000000E+000
14, 0.00000000E+000, 1.00000000E+000, 1.00000000E+000
15, 0.00000000E+000, 1.00000000E+000, 0.00000000E+000
16, 0.00000000E+000, 1.00000000E+000, 0.00000000E+000
*Element, Type=C3D8, Elset=Solid_part-1
1, 1, 2, 3, 4, 5, 6, 7, 8
** Additional elements +++++++++++++++++++++++++++++++++++++
*Element, Type=GAPUNI
2, 9, 10
3, 11, 12
4, 13, 14
5, 15, 16
*Nset, Nset=Internal-1_Internal_Selection-1_Compression_Only-1_Master
3, 4, 7, 8
*Nset, Nset=Internal_Selection-1_Displacement_Rotation-1
1, 2, 5, 6
*Nset, Nset=Node_Set-X
1, 5
*Nset, Nset=Node_Set-Z
5
*Nset, Nset=Internal_Selection-1_Temperature-1
*Nset, Nset=Internal_Selection-2_Temperature-1
** Additional node sets ++++++++++++++++++++++++++++++++++++
*Nset, Nset=Internal_All_Compression_Only_Constraints_NodeSet
9, 11, 13, 15
*Nset, Nset=Gapuni
9,10,11,12,13,14,15,16
*Elset, Elset=Internal_Selection-1_Solid_Section-1
Solid_part-1
*Elset, Elset=Internal-1_Internal_Selection-1_Compression_Only-1_Master_S5
1
** Additional element sets +++++++++++++++++++++++++++++++++
*Elset, Elset=Compression_Only-1_ElementSet-1
2
*Elset, Elset=Compression_Only-1_ElementSet-2
3
*Elset, Elset=Compression_Only-1_ElementSet-3
4
*Elset, Elset=Compression_Only-1_ElementSet-4
5
*Surface, Name=Internal_Selection-1_Compression_Only-1_Master, Type=Element
Internal-1_Internal_Selection-1_Compression_Only-1_Master_S5, S5
*Material, Name=S235
*Density
7800
*Elastic
210000000000, 0.28
*Expansion, Zero=20
1.1E-05
*Conductivity
14
*Specific heat
440
*Material, Name=Internal_compression_only-1
*Density
1
*Elastic
1, 0
*Plastic
0, 0
*Solid section, Elset=Internal_Selection-1_Solid_Section-1, Material=S235
** Additional sections +++++++++++++++++++++++++++++++++++++
*Gap, Elset=Compression_Only-1_ElementSet-1
0, 0, -1, 0, , 250000000000, 0.00025
*Gap, Elset=Compression_Only-1_ElementSet-2
*Gap, Elset=Compression_Only-1_ElementSet-3
*Gap, Elset=Compression_Only-1_ElementSet-4
*Equation
2
10, 1, 1, 3, 1, -1
*Equation
2
10, 2, 1, 3, 2, -1
*Equation
2
10, 3, 1, 3, 3, -1
*Equation
2
12, 1, 1, 7, 1, -1
*Equation
2
12, 2, 1, 7, 2, -1
*Equation
2
12, 3, 1, 7, 3, -1
*Equation
2
14, 1, 1, 8, 1, -1
*Equation
2
14, 2, 1, 8, 2, -1
*Equation
2
14, 3, 1, 8, 3, -1
*Equation
2
16, 1, 1, 4, 1, -1
*Equation
2
16, 2, 1, 4, 2, -1
*Equation
2
16, 3, 1, 4, 3, -1
** Name: Temperature-1
*Initial conditions, Type=Temperature
Internal_Selection-1_Temperature-1, 20
Gapuni, 20
*Step, Nlgeom, Inc=100
*Static, Solver=Pardiso
0.1, 1, 1E-05, 0.1
*Output, Frequency=1
*Boundary, op=New
*Boundary
Internal_Selection-1_Displacement_Rotation-1, 2, 2, 0
** Name: Displacement_Rotation-2
*Boundary
Node_Set-X, 1, 1, 0
** Name: Displacement_Rotation-3
*Boundary
Node_Set-Z, 3, 3, 0
** Additional boundary conditions ++++++++++++++++++++++++++
** Name: Compression_Only_BC
*Boundary
Internal_All_Compression_Only_Constraints_NodeSet, 1, 1, 0
Internal_All_Compression_Only_Constraints_NodeSet, 2, 2, 0
Internal_All_Compression_Only_Constraints_NodeSet, 3, 3, 0
*Cload, op=New
*Dload, op=New
*Temperature, op=New
*Temperature
Internal_Selection-2_Temperature-1, 100
*Node file
RF, U
*El file
S, E, NOE
*End step
I would really appreciate the .pmx file if possible.
Try this one:
Gap initial temp.pmx (1.8 MB)
In version v2.2.9 I cannot reproduce the problem. I tried the shared model with no luck.
