Apparently, initial temperature has to be defined for GAP elements as well. I exported the input file, added nset=nall to *Node and changed the set used by *Initial conditions to nall. It’s working.
@Matej Can you add automatic propagation of initial temperature to GAP elements if they are present in the model ?
