few CAD programs use control instead of shift to modify behavior while panning zooming and rotating. Is it possible to default PrePoMax setting? Or could you add to PrePoMax key mapping in settings?
The best solution would be the key mappings. But I looked into it a while ago, and it would require some larger code changes, so I did not implement it.
I believe this is not the most important thing. Thank you for the reply.
maybe add another key press can be useful instead of mapping.
- Ctrl+Mid-button pressed as alternative for panning, currently unused
- Ctrl+Mid-Scroll for zoom to be more smooth in scale factor.
I like the idea of a smoother scale factor while zooming.
