Cannot delete deactivated mesh
I set a mesh to deactivated, but then decided to delete it. I then realized I could not delete it or activate it again to delete it. It says the key is no longer available.
I tried to recreate the mesh and then go delete it again. it did show the new mesh but I am still unable to delete it. Here is the error found:
One can’t copy the text in windows 11 errors because that’s useful I would guess. Someone might benefit and cause the AI microslop to get sad.
I have had “missing key” errors when deleting items. I found that I had referenced the deleted item somewhere in the Step definition (History Output, BC, Load, etc.). After I removed the reference in the Step, the error went away.
I had to revert to the previous revision. Its working fine. I do that anyway, from time to time test the new features and fixes just to see if something I can use happens to be available.
It would really help to get the problematic file. As simple as possible. Without it, I cannot reproduce the problem.
I am closing this topic.
