After calculation, i pushed “Result” Button,
My Personal computer that has 32 GB memory shows “Array dimensions exceeded supported range”
Is my personal computer setting no good ?
Did you try to change the solver? Maybe the model is too large for one specific solver to handle.
This is some other issue I think. It seems the analysis was completed but while opening the results file an error occurred due to a memory issue. Is there a possibility to share this .frd file so I can check what is wrong?
Dear Matej san,
Thank you very much for your message!
Yes, you are right.
Need i upload my frd file for investigation ?
Yes, it it is possible. Use some cloud base storage as Wetransfer if the file is to big.
Dear Matej san,
I see, i will upload “frd file” after for a while.
Thank you so much!!!
