Add a time slider in postprocessing toolbar
Today for accesing a time slider control for no lineal results, we need to enter first in the animation tool and change the animation to increments, maybe a time slider directly available in the postprocessing toolbar would benefit a lot.
Abaqus has something like this:
Others has a slider directly in the GUI, no matter if the result are linear or not. Maybe Prepomax could be smarter and show it only if detect that the result is no lineal and a slider is needed.
It would have to show the slider when there are more than 2 frames then. But showing it all the time and using it to switch between t=0 and t=1 even in linear analyses would work too (same as in Abaqus, just not needing a button to activate).
But would have sense? For some reason most of postprocessors use two different tool for that. Maybe if in the lineal case would allow only two positions (t=0 and t=1) could work.
Always showing a slider regardless if it has only two positions (minimum - for linear/steady-state analyses) or more seems the best option.
In many postprocessors there are also sliders for the deformation scale factor, but they are often inconvenient (e.g., in FreeCAD it’s hard to set the range properly). A slider for time frames should suffice.
