Hi All,
I have a little problem with a simple model that I created to simulate two plates welded together.
The model is made by a horizontal plate that is welded with a vertical plate by a weld (triangular shape in the model).
I did a compound of the three shell element; I applied a surface traction onthe vertical plate a fixed the extremities of the horizontal plate.
I applied control node in both the side of the weld, because I need to extract the reaction forces.
This is the message that appear when I try to run the calculation:
Do you have an idea where I did the mistake?
WBR
Marco F.
Prova_giunto_saldato.pmx (162.1 KB)
