However, there’s no such warning when absolute zero temperature is not defined. Leaving this physical constant as undefined may also lead to incorrect results so I think that it would be good to add a warning for it as well. In the case when both values are undefined, the warning could mention them together.
Both Abaqus and CalculiX require that. They are normally unitless so the user has to specify proper values of physical constants depending on the consistent unit system he chose. PrePoMax supports units but also unitless models and the user may still want to modify the constants and ensure their correctness.
