Thermal simulation- Missing of physical constants for radiation
Hello Matej,
thank your for the awesome software. Your Software is hands down the best open source solution out there. Hope it will be popular very soon.
I found a Problem while doing a thermal analysis.
When i want to create a Surface which is radiating heat (Load =Radiation) i get the following error:
*ERROR reading *RADIATE: *RADIATE card was selected
but no *PHYSICAL CONSTANTS card encountered
*WARNING in calinput: no conductivity
constants were assigned to material WERKZEUG-PROFIL
in a thermo(mechanical) calculation
After some trouble shooting i found out that the Stefan Boltzmann constant is missing in the definition of physical constants.
When i add the following keyword everything works again.
“*Physical constants, Absolute zero=0, Stefan Boltzmann=5.6E-11, Newton gravity=0”
The problem is occuring at least in Prepomax 1.2.0 & 1.1.0
Attached a .pmx to check for your self:
Radiation_TestPrPoMx1_1.pmx (1.9 MB)
You can specify the physical constants in PrePoMax without the need to manually add keywords. Use Model → Edit to do this:
model edit
Hi Jakub,
thanks for the information i didn`t know that.
I wonder why you would not set the Boltzmann constant as a default value…
As far as i can see it is a constant which is valid all the time and cannot be changed.
It took me some troubleshooting to find the error and I dont see the point of setting it manually…
Is there anything I am missing ?
Cheers
The same approach is used in Abaqus, on which CalculiX is based. These programs are primarily unitless (only PrePoMax introduced units) and thus require the definition of physical constants depending on the unit system in a particular model. However, maybe the default values could be added for each of the available unit systems (apart from the unitless one of course) with an option to edit them.
That is true, a default values could be set for a known unit system. But if I remember correctly there were some issues with assigning values to the constants, writing the constants into the inp file and not using a keyword that relies on them. So I thought it better to let the user define them when really needed.
Hello Matej thanks for your feedback !
I cant estimate the effort of prompting a warning message just before submitting the calculation in case Radiation ist activated. If its to much then i guess the user will find this thread here which is also fine :wink:
I will think about how to inform the user about the missing constants. I do not like to have a program where warning message windows open up all the time.
I have added a warning message box in case an active radiation load is used without the Stefan-Boltzmann constant.
