Hi, i’m new to PrePoMax, and i’m initialize to study this program with examples.
First of all, i’m drawing an geometry of study on autocad and export two types of files, iges and stl.
For stl, it import as an complete part without separate parts. And it not matter if i set the units of drawing cad is unitless, inches, milimeters, etc. It imports correctly.
For iges, it import with separate parts and i create a compound part. For the drawing cad, it is important to set the unit for milimeters for correct import. When i not seted this, it was set to inches unit and i’ve needed to scale.
On SAP2000 i’m using shell elements to analysis the tension of Von Mises…
For loads and boundary conditions, i’m using two load cases to study, but for comparing i’m only applying the two loads, gravity (-9810 mm/s²) and an force (-1800kg*9,81m/s² → 17658 N). My vertical axis is ‘z’.
The boundary conditions is similarly to sap2000, i’m restrict the displacements 1, 2, 3, of the edges. On PrePoMax, i restricted the same locations, but restricted the surface. Maybe it create an difference situation for analysis.
For results, the displacement for the corner was:
SAP2000 0,4190mm.
PrePoMax 0,4494mm.
It goes well, but the tensions i dont understand…
The local it occurs is different.
Iges_model file: Unique Download Link | WeTransfer
Iges drawing file: Unique Download Link | WeTransfer
