In one of the last dev. versions, the following behaviour has changed (I’m not sure if this is a bug, so I’m posting it under “General Questions”):
Until v2.3.0 it was possible to temporary convert elemet sets to parts, use there faces to apply internal loads (pre-tension) and merge them afterward again without having a problem with the load assignment.
But now with the actual dev. versions, this assignment unfortunately gets lost. I would really appreciate it when the previous behaviour could be restored.
For clarification, please compare the end of the animations. Behaviour until v2.3.0:
Now with v2.3.dev.:
So I would currently have to omit the last step and the bolt would have to remain in two parts.
The problem comes from the idea, that after merging, the internal geometrical faces should disappear. And after that the geometry based selecions should be regenerated to account for the changees. But there was a bug in the old versions and regeneration of geometry selections did not happen. Now it does. But we loose the functionallity you described.
Sorry, but I have a follow-up question. Regardless of geometry- or mesh-based selection, the assignment of node sets and surfaces created at the “section plane” gets lost after merging the parts (this was already the case in previous versions). Is there any way to change this for the mesh-based selection so that the assignment is not lost?
No, I don’t think so. The mesh-based selection differs from the geometry-based selection in the way it is stored. Only node and element IDs are saved, and if the mesh is recreated, these IDs are invalid.
I really have no good idea of how to support this in a better way.
I have a tubular structure where I apply the bolt pretension at a cross section just above the threads. Since it is a complex part, I use second order tet mesh with a boundary layer on both sides of the cross section.
Pre 2.3.0 I was able to select the surface and merge the part back into one and was able to run the simulation successfully. But the newer versions, I can only select the FE based surface like you suggested here. I set the pretension direction “auto-compute”.
Geometry based surface selection I get the pretension direction calculated by calculix
*INFO: pre-tension normal for surface BOLTLOAD-1 -4.5946230207038368E-018 1.6354628026558331E-016 -1.0000000000000000
which is purely in z-direction (x and y values are very small and negligible for my calculation)
FE based surface selection I get the pretension direction calculated by calculix
*INFO: pre-tension normal for surface BOLTLOAD-1 0.54178583594546259 -0.84051657209651520 0.0000000000000000
I am completely getting pretension in some other undesired direction.
So I did two things
Either set the pretension direction manually in z direction for FE surface selection
Or leave the split parts unmerged for geometry based surface selection
I am still getting some convergence issues while trying the workarounds which was not present in the older versions. The older version was more convenient, is it possible to bring it back?
