Hello all,
Greetings from Toronto, Canada.
First of all, I would like to thank Matej and the team who developed such a complex software and made it available to everyone. Thank you for your generosity.
I have found PrePoMax about a week ago and started to learn how to use it.
I watched Matej’s and Jakub’s tutorials. Thank you for the efforts in explaining how to use it.
One of the tutorials I have used is Matej’s Basic Tutorial, Bracket.unv
I have two questions:
- In Set selection, the option: Surface angle has a field for angle (default is 30 deg) see image below. When should I change this angle. Matej left it as is.
- When trying to run the analysis I get the following message:
I have created an Element as Part and selected the bracket, but, it didn’t work.
Would appreciate some advice if anyone has the time to explain.
Thank you,
Paul
