I’m more used to enter traction in terms of Force per unit area.
Would it be possible to have both options in the same window?
I guess that’s just a simple conversion known the surface value.
Thank you
EDITED: By the way, is the surface value shown when I define a surface evaluated from the geometry or from the mesh?
The surface is computed from the current mesh. In the geometry module, the mesh is triangular mesh for the geometry representation, while in the rest of the modules, the mesh is the current finite element mesh.
Force per area unit is possible but additional settings will appear as for the surface spring.
Thank you Matej.
Whenever you have time. Just a reminder to get a number in the list.
I wonder how users apply wind loads when one has complex geometries in Prepomax?.
