Skateboard modeling
We are currently working on a student project involving the structural analysis of a skateboard deck. Our main interest is to evaluate the deflection and stress distribution under a static load case.
Would you recommend modeling the board as solid (3D) layers, considering that each plywood layer has a thickness of approximately 1–1.5 mm, and assigning the material properties according to the grain orientation of each layer?
Alternatively, would it be more appropriate to model the deck using shell elements with a layered composite definition?
Thank you very much for your advice.
Best regards,
Jozsef
Check this blog post: A Word About Skateboarding…. - Dassault Systèmes blog
There are also some research papers on this topic such as: https://www.irjet.net/archives/V4/i7/IRJET-V4I7544.pdf
This one is interesting too: https://www.researchgate.net/publication/397526983_Numerical_design_simulation_of_a_veneer_layer_composite_reinforced_with_recycled_carbon_non-_woven_using_the_example_of_a_skateboard
If it’s a thin (thickness < 1/10 of a typical global dimension such as length/width) laminate, composite shells would be the best way, but they need keywords edits. You can find some examples here. However, if you encounter any of the known issues with CalculiX’s shell elements (see this: Known CalculiX limitations), you may need to use the Thicken Shell Mesh tool to obtain multiple layers of solid elements instead.
