Here’s a list of the most important limitations of the CalculiX solver, particularly the undocumented ones. Some can be considered recurring bugs, while others are just unimplemented functionalities (not missing features such as analysis procedure types and material models because this can be checked here, but rather unavailable workflows with the existing features) or side effects of the CalculiX’s unusual ways of handling some things (like no true 1D/2D elements or rotational DOFs). Feel free to add more in the comments.
| No. | Limitation | Workaround | Link |
| 1 | Rigid body constraints can’t be used with 2D elements in explicit dynamics | Imitate rigid body by increasing Young’s modulus (this will decrease the stable time increment unless the minimum allowed increment size is fixed by the user) | issue 59 |
| 2 | Initial velocity is not transferred to the expanded nodes of 1D and 2D elements in dynamic analyses | Define a dummy node-based surface from the node set used for the initial velocity definition | issue 63 |
| 3 | Contact print with node-to-surface contact leads to no results of an analysis | Use contact print only with surface-to-surface contact | thread 927 |
| 4 | Models with shells, Nlgeom and rigid body constraints may not converge (in ccx 2.23, rigid body constraints can’t be used with shells at all - there is an error message) | Extrude shell elements to solids (e.g. using the Thicken Shell Mesh tool in PrePoMax), at least for the region with rigid body constraint applied | thread 369 and issue 134 |
| 5 | The first buckling mode might be skipped when the applied load is much bigger than the buckling load (also Spooles has tendencies to provide wrong eigenvalue results in general) | Use Pardiso (or at least PaStiX) for the lowest probability of such issues | issue 74 |
| 6 | Tie constraint on shells may fail when *CLOAD is applied to the slave nodes | Swap master/slave surfaces or use *DLOAD | issue 34 |
| 7 | Section print with FLUX requested, together with orthotropic thermal conductivity, makes CalculiX “think” that fluid simulation is performed, and it throws an error | Avoid section print when using orthotropic thermal conductivity | issue 70 |
| 8 | Constraining drilling rotation (rotation DOF normal to the shell’s mid-surface) may lead to overconstraint and incorrect results or even non-convergence (particularly for curved edges) | Release rotational DOFs or use a local coordinate system | issue 64 and thread 2865 |
| 9 | Shells in steady state dynamics and modal dynamics analyses can’t have modified BCs in those steps with respect to the frequency step (*BOUNDARY, OP=NEW and respecified BC also counts as modification) and load applied in the SSD step has to be applied with 0 magnitudes also in the frequency step | Avoid modified BCs and OP=NEW for BCs in linear dynamics, copy the loads from SSD to frequency steps and set them to 0 there | thread 930 |
| 10 | Local coordinate systems can’t be used for boundary conditions applied to rigid body reference points (analyses fail silently) | Use *CLOAD instead | thread 2963 |
| 11 | Reaction moment read from rigid body reference point might be zero in 2D (plane stress/strain) analyses | Use a single layer of 3D solid elements instead | thread 1312 |
| 12 | Only the last value of the FREQUENCY parameter from output requests is used | Choose one output frequency for all output requests | thread 974 |
| 13 | Models with beam elements and tied contact (anywhere) may not converge | Avoid tied contact when using beam elements | issue 83 |
| 14 | Results might be wrong for non-axis-aligned beams with rotational constraint or moment applied | Use a local coordinate system | issue 124 |
| 15 | Minimum time increment can’t be lower than 1e-6 * step time for static steps and 1e-10 * step time for dynamic steps | Split the analysis into more steps | thread 1201 |
| 16 | Results of a multistep analysis with shells might be incorrect when BC is applied to rotational DOFs and uses OP=NEW | Use solid elements instead | issue 13 |
| 17 | Analyses with creep are prone to convergence issues | Avoid very small A constant, try changing CETOL | thread 868 |
| 18 | EVOL (element volume) output doesn’t account for deformation | Calculate the volume directly from the mesh | issue 73 |
| 19 | Springs don’t work on rotational DOFs | Create a torsional spring by connecting the ROT NODES of two rigid body constraints sharing the same REF NODE with an axial spring | thread 889 |
| 20 | Distributing couplings either can’t handle BCs at all or don’t support rotations and moments | Use kinematic coupling and rigid body constraints instead | thread 2586 |
| 21 | Kinematic couplings require node-based surfaces to work with shells and *COUPLING with *DISTRIBUTING doesn’t work with shells at all |
Use solids, kinematic coupling with node-based surface or try *DISTRIBUTING COUPLING instead |
thread 4084 |
| 22 | Tie constraint may not work with 2D (plane stress/strain) elements (doesn’t connect 1st order elements and leaves out midside nodes of 2nd order elements) | Use shells, 3D solids or tied contact instead | thread 2555 |
