Select internal node for results
Hello everyone,
I have a thermal analysis of a cylinder that is heated from the outside. I would now like to read out the results of a node that is on the inside. Here in the picture the cylinder is shown in section view. However, I cannot find out the node-ID with the query-tool. Any help would be appreciated.
Thank you.
Individual elements can’t be hidden so it would be best to prepare (partition) the geometry before importing but you can also just create an element set with approximately half of the cylinder, convert it to part, hide the original part, check the ID of a selected node in that new part and undo to have only the original part again. Then you will know which node ID to use.
