Hello
I am trying to perform a steady state dynamics analysis, for which I have already defined frequency step ( with storage turned on).
As can be seen from the image, the analysis completes, but I only see the results of frequency step in the results tab.
Here is the file
Can anyone please help me find out the problem with my setup ?
Thank you in advance
When there are no results from SSD analysis, it usually means some unsupported features were used (those analyses have some limitations in CalculiX) or the setup is incorrect. Did you get any warning messages that could indicate the reason ? I would try simplifying the model gradually and rerunning to find the cause.
Thank you for the quick reply
There were no warning messages. I have done few trials and it seems that use of non-linear material has caused this problem. Can you please varify this ?
That makes sense. SSD analyses are linear and don’t support nonlinear material behavior.
Yes I have confirmed it now. My problem occured due to use of non-linear material. When I removed the plastic part, it works fine
