I want to do a very simple example.
Make a horizontal beam: length(x) 1000mm, width(y) 20mm, height(z) 10mm
Material: uniform steel
Applied forces: 1000N in z direction at 0,0,0 face. 1000N in z direction at 1000,0,0 face.
No displacement constraints.
No gravity.
Expected answer: Beam should vibrate while accelerating upwards. When the transient vibrations die down the beam deformation should behave like beam pinned at one end and simply support at the other end and under uniform gravity. It is still accelerating upwards, but the deformation is steady.
Can STEADY STATE DYANMICS find the steady deformation without doing the transient calculations?
My attempt with Dynamics
https://askoh.com/misc/acceleratingBeam.pmx
Thanks. Aik-Siong Koh
