Results not updated
V.2.3.8
When Navigating through the different results, the titles change but not the value.
For me, it works. Can you share the model or the results file?
I can’t share the files sorry. I have found that it happens with a file imported from a previous version. (2023) . Values only update when I go to a previous step and then move to the desired step again. Then it refreshes the results but freeze in that value again. It has not happened with other files. I will try to keep an eye if it happens again with new files.
Until the error reappears, I am closing the topic.
