In version 2.2.9, I seem to be having an issue in which all the Reference Points keep defaulting to the first Node_Set. No matter how many times I change the selection; as soon as I close the window and re-open it, it is back the the first Node_Set
Has anyone else had this issue ?
i have tried to replicate it on 2.2.9 but it keept the reference in my file. have you remeshed your model inbetween?
I was able to replicate the problem.
The bug fix will be available in the next developer version.
Does it work now as expected?
Yes, seems to work as intended now. Thank you @Matej
I am closing this topic.
