Dear PrePoMax Forum,
When I view the PrePoMax simulation results, the contour plot indicates the nodes for max stress and max deflection depending on which item I select in the results display pane (not sure if I am using the correct nomenclature).
If I open the .frd file for the same analysis in Notepad, I am able to correlate the numbers in the .frd file with the graphics display in PrePoMax.
CAN I CONFIGURE THE .FRD FILE TO ONLY DISPLAY MAX VON MISES STRESS AND MAX DEFLECTION?
CAN I CONFIGURE THE .FRD FILE TO CALCULATE THE RESULTANT MAX DEFLECTION?
For example,when I view the results contour plot for max stress S11, it shown that this occurs at Node id 17723.
When I look at the .frd file, I can locate node 17723 and verify that S11 = 5.49197E+04.
When I look at the contour plot for max deflection, it show that this occurs at Node id 6447. If I locate Node id 6447 in the .frd file, take the 3 components of deflection (dx, dy, dz) = (8789.13, -111631, -8297.21), and then calculate the root sum squares, I do get 1.123E05.
