urgent question: Did you change somerthing in the windows dll’ or graphic subsystem from 2.4.3 to 2.4.4? 2.4.3 works without problems in Windows emulators under Linux like wine or proton. From 2.4.4 on, the program shuts down after logo, befor opening the main window.
Linux what??? how are you running it on linux? I haven’t attempted it but that sounds awesome. I only use linux at home and this being one of my most useful and favorite work/pastime programs…I’m interested.
On the forum, there are a few threads discussing the possible approaches to run PrePoMax on Linux. Of course, a Virtual Machine with Windows would be another option.
I’ve never tried running PrePoMax on Linux, but I do have a virtual Ubuntu machine (set up using VirtualBox) so I can try running ppm with these steps and testing the issue or at least I can help you prepare such a virtual machine.
I went through all the code changes I made from 2.4.3 to 2.4.4 and I can not determine which could be so problematic. So the only way would be to have a live testing environment. I am afraid I will not be able to do that until this weekend, when I release a new PrePoMax version with bug fixes.
I have successfully created a testing environment for PrePoMax in Wine and found out that all versions work for me. I created the testing environment using VirtualBox and the latest Ubuntu, with a lot of help from GPT. I had no idea what I was doing, but below are the main commands I think are needed. I had to recreate some things multiple times…
