Prepomax example 2 wrong results
Dear Community, I am new to Prepomax and so I have started from the 2nd tutorial “Shaft with surface traction loading” from 2021.09.07-PrePoMax-v1.1.0-examples-manual.pdf to understand interface and prompts.
The problem is that in this model my stresses and deformations are really bigger than the ones from the example (it happened to get really big stresses and deformations also for other models I tried to analyze).
It looks like some units are wrong in the stiffness or in the loads. Is there a beginner to tip to take into account? I would really appreciate your help.
Aren’t you using the Concentrated force load by any chance ? Then see this: Don't apply concentrated force load to surfaces
Otherwise, please share the .pmx file.
Thank you, solved as you said.
