I’m new user of prepomax, comparing it to other open source software the user interface is very good.
I’ve ran a bench test comparing the same model & same loads and constraint.
the results displacement result are: Solidworks 0.5 mm, prepomax 9 mm.
Can someone explain what I did wrong? attached the PMX files.
Thanks,
Oren
You should apply the load differently (e.g. using a rigid body constraint) or divide the total load by the number of nodes and then use the concentrated force.
also, it can be use Surface traction feature in PrePoMax, it seems the behavior is similar to *Coupling type *Distributing, but it lacks of rotational forces (concentrated moment).
