I would like to propose to have the deformation scale factor setting more easily accessible - perhaps an icon and drop down choices within the Results menu.
It would make it a lot quicker to access than having to go into setting every time you want to change it.
I will se what I can do I like the idea of “Undeformed with color contours” option and also some shortcut to select the scaling factor directly. Maybe editing the value in the status block directly by double clicking it. This requires some additional work but might be the shortest shortcut.
Hi Matej,
This looks great and easily accessible. Thank you. ! I cant wait to try all the upgrades when 1.3.3 is released.
The image below is from Ansys, where they include some preset values, which may be handy as a ready made choice for the user.
