Hi all,
I hope a short paid-work post is OK here (moderators, feel free to remove it if not).
I’m Jeroen, and I’m running a project with a steady stream of structural FEA tasks, done entirely in PrePoMax / CalculiX with Gmsh. I’m looking for people with real, hands-on experience in these tools, for two different roles.
The work:
- Take a real CAD part or small assembly (STEP), simplify it, and set up the analysis in PrePoMax/CalculiX
- Mostly static analyses, with some contact, bolt pretension, plasticity, buckling and modal work
- Write a short, unambiguous brief and build a validated reference solution (mesh study, converged result)
Role 1: FEA engineer (several people)
- Solid hands-on FEA experience, and actual project experience in PrePoMax/CalculiX
- You don’t have to be a top specialist; careful, independent work matters most
- Abaqus experience is a plus (similar input format)
- 20–40 h/week, €70–100/h depending on experience
Role 2: PrePoMax/CalculiX expert (one person)
- A proven expert in PrePoMax/CalculiX specifically: you know the solver’s behaviour, contact and convergence settings, and its limits inside out
- Takes on the hardest analyses and supports the other engineers
- Flexible hours, at a higher rate (100+/h)
For both roles:
- Remote, freelance, through end of November and possibly longer
- Start as soon as possible: a short call first, then a paid trial task
If you’re interested, send me a private message here with a few lines about your FEA background, which role you’re interested in, and a link to your profile or some of your PrePoMax/CalculiX work.
Thanks, and thanks to Matej and everyone here for PrePoMax!
Jeroen
