Output result on Axisymmetric cylinder
When you make an axisymmetric analysis, you can chose two way to have the output result : in 2D or in 3D. The way to have the result change between the two settings. For example I juste make a simple analysis on a 10 mm diameter cylinder (20 mm lenght) . I applied a 0.1mm displacement in Y direction.
First i solve the reaction force with a simple analytic methode :
Then i make an equivalent model in Prepomax :
Now you have to choice to have you Element field output :
And here you have the two settings solved :
On the 2D methode the reaction force is given for all the cyclinder surface.
On the 3D methode the reaction force is given for a 2 degree portion of the total surface of the cylinder .
So think about that when you change your output !
Yes, although documented, it can be confusing: Reaction forces in axisymmetric model
Why does the cylinder look discontinuous?
I guess it’s just a circular transformation on the standard 2° wedge. One should enter e.g. 2° angle and 45 segments to get 90° visualization.
Yes exact you can choose how you pattern your result output. 2 degree it’s
continuous.
For the visibility i set : 4 degree.
