Hello everyone,
I have been working on an analysis that I originally ran in ANSYS. I exported the mesh to Gmsh in BDF format and then imported it into PrePoMax using the INP format. I set up all the connections similarly to what I had in ANSYS, and the mesh is identical, yet I am getting a nonpositive Jacobian error. My model includes both shell and solid geometries. I am investigating a grounding (bottom impact) scenario for a sailing yacht the keel is modeled as a solid and the hull is modeled as shell elements. The upper part of the keel is connected to the hull, while the lower part is free. I defined nodesets at the bolt locations and applied rigid body constraints, and I also added a compression only contact between the two sections of the keel. The analysis runs successfully in ANSYS, but when I replicate the same setup in PrePoMax I get this error. Any help on identifying the cause and resolving it would be greatly appreciated. Thank you.
