I have carried out the analysis of a round bar subjected to a tensile load. I have considered the non-linearity of the material. But an error occurred in the analysis. I have attached the PrePoMax analysis file with this.
Thank you
Plasticity is causing non-convergence in this case. You may have to change the definition of the plastic behavior. First of all, use zero plastic strain for the first point. Then try providing more points and adjusting the values.
If it doesn’t help, try displacement control and different boundary conditions. You could also use axisymmetric model for this study.
Hi @TOMIN!
as @FEAnalyst said, you should provide a proper plastic curve data in your model, the actual one started with a non zero plastic strain value and extend its range adding more points to the curve (fitting material real behavior)
In addition to that, I have noticed that the applied load is really high for the net section area of the bar, making difficult to achieve convergence under your actual configuration (mesh, material data, load steps…), and even could have no sense for a non linear static analysis.
My recommendation, fix the material data and start with a a more discrete load magnitude if you are just testing PPM. If it is not your case, try with a displacement controlled approach.
I am attaching the analysis file of the same bar supported at both the ends and non - linear analysis is carried out. I have changed the plasticity parameters and reduced the load. But an error occurred.
Same recommendation for this bending case, review the load magnitude and its application scheme, it seems to be extremely high for your non linear static model. What are you trying to represent with these models? are just for testing purposes?
