*NO ANALYSIS Vs CHECK MODEL
I was planning to visualize the result of some imperfections I have introduced on my geometry . I have request Check Model . My file has no Steps. My idea was to just generate and load the geometry to magnify the deformed view.
Is Check Model in Prepomax the same as *NO ANALYSIS ?
Although there are no steps in the tree, the results windows in Prepomax is loading some previous results from the temp folder as I can see a set of Mode shapes as if there has been a Frequency analysis. (There was before erasing the steps).
Regards.
 Job finished
________________________________________
Total CalculiX Time: 5,146010
 Job failed - no results exist.
Process elapsed time:       5.566 s
Yes, Check Model uses *NO ANALYSIS. But since PrePoMax adds this keyword after the actual analysis step, it won’t work when there are no steps or the steps are deactivated.
And when the analysis fails with no results, you may still see the previous results (that were not replaced because new resukts were not generated) in the Results tab. You can use File —> Close All Results to get rid of them. Clicking Results in the job monitor or job context menu should (correctly) show an error message about non-existent or empty results file.
Hi, guess that is related to this, is there a way to preview the thickness for shell elements before launching the solver?
To inspect imperfections or detect unexpected behaviours It would also be needed a scale in specific directions.
Kind of:
Variable:Deformation
Type: User defined
Factor: User defined
Direction: GLOBAL,X,Y,Z (New)
Yes, it is the same. The *No analysis keyword is step based according to Calculix documentation so it must appear within a step. I could add a dummy step if no other steps are created in the model?
Exactly this Check Model option can be used for that. There’s no rendering of shell thicknesses in preprocessing like in Abaqus.
Right, this would make sense.
I have added a CheckModel step in cases when there are no active steps in the model.
Thank you Matej.
I have done some other tests but unfortunately *NO ANALISYS by itself doesn’t generate the expanded geometry in the results window unless there is a dummy BC in the dummy step.
I added a step without a BC, and it expands the shell.
same here, even i feel it every time :winking_face_with_tongue:
