Greetings,
I recently started using PrePoMax to analyze the deformation and torque generated by a thin film.
My goal is to first pre-stress the film and then measure the torque generated during rotation.
The film is modeled using shell elements.
Current workflow:
Step 1
The straight film is deformed by moving F_initial to an intermediate arbitrary point before reaching the F_inner position.
(The film twists if F_initial moves directly to F_inner, so I split the process into two steps.)
The surface is fixed to F_initial using a rigid body constraint.
Step 2
The deformation is completed by moving F_initial to the F_inner position.
This step creates the initial pre-stress in the film.
This becomes the initial condition of my device.
Step 3
I would like to rotate the surface around the axis defined by reference_point_1 to measure the torque as a function of rotation angle. However, I could not achieve this using a multi-step analysis. The screenshot above shows a separate analysis to illustrate an example. In this case, the film did not start from the pre-stressed state.
I encountered the following difficulties.
Questions:
The F_initial position is reset when a new step starts.
I currently need to manually reposition it using displacement/rotation boundary conditions and amplitude definitions. Otherwise, the analysis crashes.
Is there a way to continue the analysis using the deformed configuration from the previous step without redefining boundary conditions? -
I cannot change constraints between steps.
The surface should detach from F_initial and then be attached as a rigid body to reference_point_1.
However, I could not find a way to change rigid body constraints between steps.
Running the steps separately is possible, but the film must remain pre-stressed before the rotation in order to measure the torque correctly. -
Additionally, I suspect the film may exhibit bistable buckling behavior depending on the fixed position. Can PrePoMax handle this kind of problem?
Unfortunately, due to company security policies, I cannot upload the PMX file.
PrePoMax version: 2.4.0
Thanks for reading.
