Recently, there has been quite a lot of confusion around multistep analyses so let’s try to summarize the important rules (based on Abaqus but it should be the same in CalculiX), assuming that we are talking only about non-perturbation procedures:
The
OPparameter:
This parameter is used by features like*BOUNDARY,*CLOAD,*DLOADand so on. Its default value isMODwhich means that said features are propagated (remain active) or can be modified with new values in subsequent steps. The non-default valueNEWmeans that all features of a given type are removed unless they are respecified.
It’s also important to mention that when boundary conditions are removed, the solver replaces them with equivalent forces and ramps them down to zero during the whole step (or removes them immediately in dynamic analyses due to a different default amplitude). When loads are removed, they are also ramped down linearly or removed immediately depending on the amplitude. Of course, the same applies to new prescribed conditions - they are ramped up or added immediately according to the default amplitude. -
Prescribed values:
Magnitudes of prescribed conditions (BCs or loads) should always be given in terms of a total value, not as a change in magnitude. So BC set to 0.5 mm in the first step and 1 mm in the second step means that the nodes will move further 0.5 mm (to reach a total displacement of 1 mm) in the second step. If a magnitude is left unchanged (0.5 mm here) then nothing changes. Same with loads - they remain constant if there’s no amplitude.
What’s important, setting BC magnitude to 0 in a subsequent step returns the nodes to their original positions. -
*BOUNDARY, FIXED:
This parameter makes sense only in steps other than the first one. It means that, during the step, the specified DOFs remain fixed (frozen) at their values from the end of the previous step. Thus, any new magnitudes are ignored. -
Material state:
Apart from the above rules, there’s one additional important aspect to consider. The state of the model at the end of a step is carried over to the next step. However, if the system is conservative (fully elastic) then there will be no impact on the results of that subsequent step. So each step is load path independent because there’s no permanent (plastic) deformation. The same applies to contact - if there’s no friction then the system is conservative so the solution does not depend on the load history but only on the final load.
EDIT: Small clarification for point 4:
If Nlgeom is enabled, geometric nonlinearity will still be taken into account even in conservative systems. Consider a classic Hertz problem with linear elasticity, Nlgeom, no friction, and two steps - the first one with displacement control (to establish contact) and the second one with load control. Geometric nonlinearity will be taken into account (deformation from the first step will be used as the starting point of the second step), but there’s no load path dependence, and thus loading from the first step will have no effect on the results in the second step (other than affecting the geometry used at the beginning of the second step due to Nlgeom).
Another example - a 3D bar with hyperelastic material subjected to tension. Regardless of the load history, the result will only depend on the current elongation/strain. However, if you consider a linear spring element, it has no cross-section, so there will be no geometrically nonlinear effects (such as related to cross-section thinning with elongation) that would normally be observed when using solid elements, so you can’t preload such a spring in the first step to have it already elongated at the beginning of the second step.
