A model is created and exported from Autodesk Fusion as STL file for FEA in PrePoMax but however, it could not be meshed in PrePoMax. it can be previewed but meshing took forever without completion. Any advice or guidance would be highly appreciated. Thank you.
@ANYS STL files are recognized as solids and meshed independently of their facets in PrePoMax. However, it’s better to use STEP format to make sure that proper faces will be available for BC/load/constraint application.
Can you share the file ? Did you try changing meshing parameters ?
This geometry is really tricky. There are some artifacts in form of tiny free-floating parts, for instance. I would clean it up in Meshlab or Meshmixer first.
i replied an old topic and it maybe too late, but can be useful for another user facing similar problem to deal with complex model of Stl files. It seems TetWild can handle example model given, below some screenshot at testing.
