Joint (3.0.0 RC2): transmitted forces cannot be recovered + crash with kinematic coupling on shell edges
Hi all,
I’m testing PrePoMax 3.0.0 RC2 on a simple linear static model: two shell plates (6 mm) connected by two bolts, with no contact between the plates (I want to stay linear).
Setup
  • Each bolt is modelled with the new Joint constraint, Spring formulation, applied directly to the hole edges of the two plates.
  • I tried both Ball and Hinge joint types. With Ball the deformed shape doesn’t look physically meaningful. With Hinge it does, but I’m not sure it’s the best choice for this kind of connection.
  • It’s also not clear to me whether Hinge or Weld is more appropriate for a bolted joint like this. Any advice is welcome.
Ideally, I wanted to create a coupling between each hole edge and its own reference point, and then define the joint between the reference points of each bolt. I couldn’t do it because the couplings didn’t work (see below), so I applied the joints directly to the hole edges.
Is there a way to get the forces (and moments) transmitted by each joint? I need the shear and axial force per bolt for the bolt verification. In History Output I don’t see any joint-related option, and I couldn’t find anything in the documentation (the latest manual is 2.6.0). Is a dedicated output available or planned?
When I tried reference points with kinematic coupling on the hole edges, I found a malfunction: CalculiX crashed with exit code -1073741819 (access violation). Removing the kinematic couplings solved it.
I can share a minimal .pmx if useful.
Thanks!
First, a comment on coupling constraints - at least most of them don’t work with shells or require specific workarounds, it’s a known CalculiX issue: Coupling constraints with shells - Analysis issues - CalculiX (official versions are on www.calculix.de, the official GitHub repository is at https://github.com/Dhondtguido/CalculiX).
So you can try using kinematic coupling with a manually defined node-based surface. Or just switch to solids using the Thicken Shell Mesh tool - that’s usually the best option considering CalculiX’s limitations with “fake” shell elements internally expanded to solids anyway.
When it comes to the new joints, their primary purpose is modeling mechanism-like connections; hence the hinge, ball, and most of the remaining types. Internally, they just constrain different DOFs via *EQUATION.
For bolted connections, I would choose a different approach. Since 1D elements are hard to use for bolt modeling in CalculiX (you would need a few 2-node springs or beams for each direction and could encounter various issues), usually the best option is to model bolts as simple solid cylinders.
Extracting forces from 1D bolt models in CalculiX would also be problematic; for springs, you need either reaction forces from nodes with BCs or you can calculate the force from the strain energy: Extracting springs force and elongation - Uncategorized - CalculiX (official versions are on www.calculix.de, the official GitHub repository is at https://github.com/Dhondtguido/CalculiX).
For shells and solids, apart from reaction forces, you can try Section Output. If you model the bolts as solid cylinders, this feature will let you obtain the forces directly from the cross-sections.
Also, see this approach: https://www.youtube.com/watch?v=pS-OEiUN488
